Nylon supply and return tube where to get it??
I was hoping that someone could shed some light on where to find this stuff. I am looking for the nylon supply line and return lines that go on top of the fuel tank. Unless you know of a company that makes an adapter for those fitting to use stainless steel braided hose. My nylon tubes got kinked a little bit last time I pulled the tank down and I think it is what is causing my other pumps to have failed. Thanks for any info, Paul M
I used the same adapter fitting that everyone uses to connect braided line from the rails to the stock feed line. I believe the return is the same fitting but in 5/16. They are the push on with -6 AN male on the other end.
Feed: http://www.summitracing.com/parts/RUS-640850/
Return: http://www.summitracing.com/parts/RUS-640860/
You wouoldn't happen to have any part numbers or direct me to a page where I can see some of them? I think that I am gonna do what I read in another post about using an adjustable FPR on the schrader valve of the stock fuel rails, and I will also be needing the adapter(s) to make a stainless steel braided hose return line work.
we use this guy for all our custom tubes..
http://www.tubetechweb.com/
ask for James, tell him we sent you he will give you a break
Sweet, thanks for all the info guys. Looks like I have some money to spend and hopefully this thing gets fixed once and for all, with adjustable fuel pressure to boot!
WE JUST DID OUR 70 CHEVELLE, every tube from a custom tank to the rail, back to the tank with all an fittings and frame mount using aircraft braided tubing was 495.. not bad, our 55 he charged me 330 with all fittings and nylon.. But, this stuff is really nice... I think he has ready made kits for the camaros for a lot less.. Find out a call is all it will cost
You mean that they have already made kits that convert the nylon supply and return tubes on the top of the fuel tank into stainless steel braided hose? That would save a little bit of time I suppose.
