Help with 98 fuel line routing!
Old 08-28-2009, 11:36 AM
firehawkclone's Avatar
Default Help with 98 fuel line routing!
Im doing a 98 ls1 swap in my 95 firebird racecar and im trying to fine out what are the 4 lines that are coming out of the fuel pump. For the lt1 i had the feed/return(SS lines) run through the car. Now the 98 gets a feed and a vapor. So i will just switch them over but i need a little help.
In this pic the 3rd one from the left is the feed right? What are the other 3?
Ive searched but only found pump installs, no mention of the lines config!
Thanks for any help!
Old 09-05-2009, 12:35 PM
Hamrdown's Avatar
Send me a pm with your email address and I'll send you pics and a diagram of where everything goes later tonight.
Old 09-05-2009, 12:40 PM
Powerhouse's Avatar
What did you cut that with? A chainsaw?
Old 09-06-2009, 11:20 AM
dlandsvZ28's Avatar
This tool is your friend. Get one at Harbor Freight to cleanup the hole you cut. It's cheap, easy to use, and makes a perfect cut.
http://www.harborfreight.com/cpi/cta...emnumber=65895
Carbon monoxide fumes are NOT your friend. Make sure you seal the hole when your put everything back together.
Old 09-06-2009, 05:08 PM
Gen414's Avatar
LMFAO!! I wanted to say something, but I just couldn't and then I read your post.
To OP...sorry for laughing, but I was having a bad day until I read Powerhouse' post...now everything seems all right
