Guys running race gas
For those of you running 110. How often do you change your plugs? I noticed after alittle bit of cruising..they fouled out. Changed um out. went racing. I had to do alittle bit of street driving for a photoshoot. Prob 10miles worth. Just curious about you other guys. These are ngk-tr6 plugs.
LS1TECH Sponsor
Are you talking leaded gas? This can foul out plugs due to the o2 sensors getting contaminated...
If unleaded, it will cause no problems & under these circumstances, you either have a tuning problem, a bad o2 or some other issue.
The TR-6 is not a cold plug that should have any problem with extended street driving.
