estimate on max hp on 80 psi injectors on e85
Old 10-08-2009, 12:13 PM
transdam's Avatar
Default estimate on max hp on 80 psi injectors on e85
want to tune on e85 goal is 600rwhp on 80 psi injectors and twin pumps and a 8an fuel line stock line as a return
procharged around 12 pounds of boost
80 to small or just right?
Old 10-08-2009, 06:17 PM
vaticano's Avatar
You should be fine. I use racetronics 79# injectors with dual pumps and the stock fuel system.
Quick Reply: estimate on max hp on 80 psi injectors on e85
