fuel cell foam how to remove?
I have a 1 gallon fuel cell for my nitrous system and I pulled mine out by removing the cap and ring assembly, not very easy, but once I had it off, I could get my big paws in there. I removed it before i drilled and tapped a fitting, cleaned it, and then put the foam back in, I would recommend keeping the foam and re-installing it once you have cleaned it. the foam was not very easy to pull out and harder to put in by the way, but can be done.
