Fuel Volume Requirements - E85 Carb
Old 10-21-2009, 09:42 AM
Tireburnin's Avatar
Default Fuel Volume Requirements - E85 Carb
I'm planning on running a carb on my new 416 LS3 setup. It is all finished up except for the carb and I plan on using a Pro Systems E85 carb. I hope the engine will make 700ish hp on the engine dyno.
For this setup, what kind of pump volume and fuel line size requirments should I plan on? I was thinking dual Walbros in tank with 10an line up to an areomotive regulator (to step the pressure down to 8ish psi) with 8 or 10an line back to the pump.
Would that be enough fuel volume? Would a single intank pump with the big lines be enough?
