Need advice on my fuel system.
ok.. i dont really like that setup i just posted. Now thinking about it. How does this look...
-8 feed, stock feed used as return directly into bucket/venturi. Dual walbros, second one being boost referenced activating at 1 psi
I do not know were or how you get those pictures drawn, but no the fuel should go from pump to filter to a Y then to the fuel rails, then y back into the fuel pressure regulator. The excess fuel then goes back to the tank.
Or you can run the fuel to the filter, then into one fuel rail, then into the other fuel rail then to the regulator and then the excess fuel is dumped to the tank.
