Fuel system for 5 to 600hp with room for growth?
Old 11-14-2009, 07:47 PM
Otto-813's Avatar
Default Fuel system for 5 to 600hp with room for growth?
To start I plan on getting 500 to 600hp out of my 4.8. Forced induction (T70 MP) is the way im going and have a question about my fuel setup.
I plan to run 2 walboro 255s each with -6an feed lines to speed inc fuel rails. Regulator is the -10an aeromotive (13101) with -6 return. Also going to use the 60lb modded LS2 injectors from fuelinjectorconnection.com
Just wondering if I could take the two outputs from the pumps and run them to one -10 (or -12) feed line then split them up again at the rails?
Also are the 60lb injectors going to be over kill for that much hp? I plan on getting into the engine down the road but only wanted to mess with the fuel system once.
Thanks for any input!
Old 11-14-2009, 07:57 PM
LS1TECH Sponsor
Lonnies Performance's Avatar
You will be OK with the 60's but are way out of the ball park with a -10 line.
-8 is all you will ever need.
If you are looking for a complete kit, let me know. I have dual pumps & complete line kits in stock.
Old 11-14-2009, 08:48 PM
Otto-813's Avatar
So I could join the pumps on an -8an line then split them back up?
Old 11-14-2009, 08:55 PM
LS1TECH Sponsor
No need to split them back up. You can run the rails in series.
Old 11-14-2009, 08:56 PM
Otto-813's Avatar
Ah ok, thanks a lot!
Quick Reply: Fuel system for 5 to 600hp with room for growth?
