Empty fuel tank using fuel pump?
Old 11-19-2009, 08:48 PM
Jazz-LT1's Avatar
Default Empty fuel tank using fuel pump?
I've had gas in my fuel tank for almost a year now while doing my engine build and it wasn't stabilized before hand. I honestly didn't think the build was going to take that long. Would it be okay to hook a hose to the return line and jumper the fuel pump relay to pump the fuel out of the tank? Any opinions?
Old 11-19-2009, 10:02 PM
LS1TECH Sponsor
Lonnies Performance's Avatar
You could, but it would be better to use the fuel line to the engine to drain the fuel instead of the return line.
Actually 1 yr old fuel usually is OK, but may smell a little funny as long as you do not run the vehicle hard.
