Injector Help!
Old 11-23-2009, 07:44 PM
468CH3V3LL3's Avatar
Default Injector Help!
I was wondering what type of injector to get? I have a 2001 WS6 and i will be installing AFR 205's, 226/230 cam, stock ls6 intake, Racetronix fuel pump and wiring harness, and all supporting mods. I am pretty sure that i want 42lb/hr injectors so i have room to grow, possible 100-150 shot down the road!
My question is which brand do you suggest? Bosch "blue demon" injectors from FIC any good? Keep in mind i am on a budget!
Thanks for your help!
Old 11-23-2009, 07:51 PM
FICINJECTORS's Avatar
the "BLue Demon" is the older style Bosch that are flow matched. We now use the design 3 like the one in your car. They are e10 compliant and fit right in. I can sell you a set for 239 plus your old ones. These will be 42 that will flow 50 under the ls pressure. I really think you should get 36 that flow 42.. same price
Old 11-23-2009, 08:00 PM
Will the 36 lb's be enough for my setup plus a 150 shot? I thought i read somewhere about the hp level certain injectors could support and i fell into the 42 lb range? 42 lb'ers overkill?
Old 11-23-2009, 08:02 PM
is your squirt kit going to be wet or dry?
Old 11-23-2009, 08:04 PM
Wet shot
Old 11-23-2009, 08:10 PM
E-Works's Avatar
hmmmmmmmm....
Wet shot
on a wet shot the fuel is not metered through the fuel injectors. So the 36 is what you need. they will be 42 in your rail. thats plenty.
Old 11-23-2009, 08:19 PM
Okay thanks for all of your help!
Old 11-23-2009, 08:21 PM
Could you post a link to the injectors you mentioned? Thanks
Old 11-23-2009, 08:26 PM
http://fuelinjectorconnection.com/sh...&productId=179
Quick Reply: Injector Help!
