Fuel t-fitting
Old 11-24-2009, 07:08 PM
niceguyyy01's Avatar
Default Fuel t-fitting
Ok, so I have searched and searched. Where does the line coming out of the t-fitting (by the fuel filter) go to? Do I need to keep that line? I am replacing the feed line and return lines with braided stuff and a new billet fuel filter.... but what do I do about this line?
Old 11-24-2009, 09:09 PM
Kleeborp the Moderator™
MeentSS02's Avatar
The one side comes in from the gas tank, one goes back to the tank (return line), and the third side goes forward to the fuel rails.
Old 11-29-2009, 06:17 PM
So there is actually two return lines? Can I just cap that one off and run the return line from the rails back to the tank?
Old 11-29-2009, 08:20 PM
MeentSS02's Avatar
One question - I was assuming you were asking about an F-body fuel system. Is this the case?
If not, the answer may vary. On an F-body, the return back to the tank (where the regulator is) is back there at the t-fitting. The fuel going forward to the rails stays at the rails and never returns to the tank.
