LS3 Pump/regulator options
Hello everyone,
I am swapping a stock LS3 into my C4 and have a couple questions...
What fuel pump is recommended? I am thinking of going with a GM pump as I have heard of reliability issues with aftermarket pumps (Namely Walbro.) I had planned on going with the 25163473 pump but read a post on here that stated it might not be enough...
Will the C5 filter/regulator work with the LS3?
Thanks!
Thanks!
Replacement Walbro is what you need...you would be surprised the GM pumps you are looking at are most likely Walbro pumps they make 90% of factory pumps when installed correctly they are just fine. The C5 filter/reg will work too. I have swap kits available to plumb your setup. Give me a call I will help you get what you need.
