Will the Ford 80# SD injectors/EV6 fit LS2?
Will the Ford MS 80# SD injectors with the EV6 connectors fit the factor LS2 intake/rail setup?They look longer in the pictures than my injectors. I have speed inc rails with the stock manifold. Thanks.
no they will not without spacing up the rails.Also your covers wont fit after that. The FMS 80 is 60mm tall and the LS2 is 48mm.. We have 80 ls2 injectors that will drop right in. Do you already own the 80's?
I corrected it.. they will support 1050 CHP (crank horse power) or about 950 RWHP DS= duty cycle..85% is the max I like to go, But, 80 is optimal.
