Converting stock feed to return
I'm looking for the adapter to convert a -6AN to the stock feed line (with the quick disconnect) so that I can use my stock feed as the new return.
Is this the correct adapter?
http://www.summitracing.com/parts/RUS-640853
Thanks
EFI Fitting, Push-On, Straight, -6 AN to 3/8 in. OEM Hard Line, Black, Each
Thanks
Using the factory feed as the return really does not save much its about $70 extra in line and you need specialty fittings to plug the "T" by the filter and you need to replace the filter with a new one as to not push all the debris back to the tank.
GTO's don't have an inline filter so I don't have to worry about that.
For me it is not about money, its about keeping it as clean and OEM looking as possible, even if it takes double the cost.
i used a hard tube adapter for my retrun and its been leak free for like 6 years.
like this
http://www.jegs.com/i/Earl%26%23039%...65106/10002/-1
like this
