82 el co ls1 how do i set up the fuel system?
do i need a new fuel tank and get a better pump with it i know ls1 fuel system needs 60 psi . do i need a fuel pressure regulator and do i still use the charcoal canister ???????? im confused
If you can get a Walbro in your stock tank that would work. Will the motor be fairly stock? I have a fuel line kit to use the Corvette filter/reg. to hook to your tank and up to the stock fuel rails or we can add aftermarket rails too. Give me a call I can help you put something together.
