No fuel pressure after v6 to v8 conversion
Old 12-12-2009, 09:41 PM
tazmo65's Avatar
Default No fuel pressure after v6 to v8 conversion
Here's my problem, I have a 98 firebird that had a v6 in it and I changed it out for a 383 ls1. I took the fuel lines from the doner car but not the tank or fuel pump. Now I am trying to start it but no go. I have fire but no fuel at the fuel rail. What am I missing? I can hear the pump running but no pressure!
Old 12-12-2009, 09:42 PM
71 chevelle's Avatar
Check you return lines. you may have your line reversed.
Old 12-12-2009, 10:11 PM
tazmo65's Avatar
Question
I took the regulator out of the fuel rail and did have a steady steam of fuel coming out but nothing at the test port with the regultor installed
Old 12-12-2009, 10:25 PM
can you give more info on your fuel set up? did you change the stock pump out and replace with one to to handle the v8. do you know what the pressure at the rail is?
Old 12-12-2009, 10:39 PM
tazmo65's Avatar
All I did was change out the fuel lines as the v6 had 3 lines coming to the engine and the ls has only 2. the fuel pump and tank are from the v6.
Old 12-13-2009, 01:01 AM
KrisXpc's Avatar
you have the quick connects crossed above the fuel tank.
Old 12-13-2009, 09:54 AM
LS1TECH Sponsor
Lonnies Performance's Avatar
The V6 car had the regulator on the engine, not in the tank. You need a V8 sender with the regulator or you will not have any pressure.
Old 12-13-2009, 12:58 PM
tazmo65's Avatar
I just pulled the shrader valve out at the tap on the fuel rail and cranked the engine. I had fuel flow at the rail so I hooked up my gauge to the port but had no pressure. So the regulator in the tank is in addition to the one on thr fuel rail?
Old 12-13-2009, 05:04 PM
LS1TECH Sponsor
An LS1 f-body engine does not have a regulator on the rail.
That is a pulse dampener not a regulator on the rail... plus you do not have a return line up there.
Get a fuel sender with a regulator in it & use with the V8 lines..... this is your problem.
