fuel system for 100-150 wet shot,cam,boltons
My car is currently cam/bolt ons but i recently ordered a hsw wet plate kit.I dont know too much about fuel systems.I was going to go with the Racetronix pump, and FAST rails.Is a regulator needed?if so how do i go about installing one and what kind should i get?any other pointer are greatly appreciated
1) Racetronix kit
2) dont need rails, so forget that
3) Dont need a regulator, forget that
3) Might consider a stand alone as a "future" upgrade, but not needed now either.
Pretty straight forward, just get a PnP racetronix kit with the hotwire and go to town. Anything 150 and south should be no problem for the drop in kits from Racetronix.
1) Racetronix kit
im running a racetronix kit w hotwire kit and with svo42lb injectors with 100 wet shot,but im a 383 stroker,i also have the fast rails,no regulator.if you have cam and bolt ons id upgrade ur pump and injectors i found out the hard way and melted piston 7 cause my stock injectors were maxed out.
