stock or 36lb injectors
i have a 99 ta a4 2500 stall, built tranny, lt, lid, p&p tb,p&p maf, bbk ssi intake, 100 wet shot, and i have some ford 36lb injectors so my question is would it be worth paying $80 for the wiring adapters and if i did so would i see a difference and how much?
what pn injector do you have.. give me the number that starts with 0280, because 36's were all made with the same plug as the ls1, only 39's had the us car plug. Also if they are 39 they will be rated at 39.15 psi fuel pressure.. also snap a pic so i can tell you what you have.
the numbers are 0280 155 865 and instead of the rectangle ls1 plug in with tabs on three sides this injector is square with two tabs on one side (right side) i took them for trade as 36lb ford injectors not exactly knowing what they were. im spraying 100 wet shot from a fogger system and i thought i should upgrade my fuel system should i change my fuel pump also? if so what kind also doing a cam upgrade in maybe a month if that changes anything
