1000hp-->1400hp fuel system upgrade build
Looking for thoughts/insight on my new parts selection. So I am on a REAL limited budget and need to supply more fuel to my car as I switch from a single 80mm to twin turbos that will make up to 1300ish whp.
old set-up:
dual in-tank walbros
-8 feed/-6 return
nasty rails
fuel lab boost FPR
96lb injectors w/ driver
New plans:
sumped custom fuel cell
dual parallel bosch 044s
dual -8 feeds to each rail
-8 drain
same fuel lab FPR
160lb ford motorsports injectors (snatched for $200 from a friend!)
Does my line sizing sound adequate?
Diagram
old set-up:
-8 feed/-6 return
nasty rails
fuel lab boost FPR
New plans:
-8 drain
same fuel lab FPR
Diagram
I don;t want to undershoot the injectors with 120s, but I am nervous about getting the car to idle decent with 160s and the stock PCM.
