E85 Tune
You can probably get away with a walbro with a boost a pump and 60lb injectors. on ls1gto there is a few e85 boosted goats that are running that set up with a duty cyle at 90% so for you your duty cycle would probably be in the neighborhood of 60% which is pretty much optimal...
