Victor Jr. fuel rail question
Old 01-20-2010, 12:34 AM
ninetres's Avatar
Default Victor Jr. fuel rail question
I ordered the Victor Jr. with the rails and NOW notice they are 3/8"......not 1/2" or -8 ports.
My fuel system is designed with dual -8 feeds and I am not sure how putting 3/8" to -8 couplings on them will affect flow. My Fuel Lab FPR also has -6 ports.
1. Will it be okay to run the rails and FPR with adapter couplings on them or do I NEED to upgrade to -8 parts?
2. Are there even any rails out there that are -8 and bolt onto the Victor Jr.???
The system will need to flow 1300 whp.
Old 01-20-2010, 01:08 AM
uphigh07's Avatar
hey man i have asked this ? before and was told they would good for 1500 plus hp, i would wait for others to chime in also maybe some first hand experiences
Old 01-20-2010, 11:59 AM
Nasty N8's Avatar
You will have no problem with them 3/8 pipe is different than 3/8" its about the same as -8 size wise.
Nasty N8's Avatar
Just use teflon paste on the treads.
Old 01-20-2010, 01:13 PM
Goldfinger911's Avatar
Be sure to check if they are pipe threads or straight threads. If they are pipe, then use a small amount of teflon paste. If they are not pipe, then you dont need paste... they are meant to use an o-ring. I am running the FAST aluminum fuel rails (red ones) with my Vic Jr and they are not pipe threads. I needed a fitting that was AN-to-AN with an o-ring.
Just didnt want you to **** up your rails.
AN-to-Pipe: http://www.jegs.com/i/Russell/799/660483/10002/-1
AN-to-Straight(AN): http://www.jegs.com/i/Magnafuel/665/MP-3013/10002/-1
See the difference?
Old 01-20-2010, 01:14 PM
ninetres's Avatar
Thanks Nate. Same with the -6 fuel lab FPR? It will suffice?
Old 01-26-2010, 11:10 AM
n20kid's Avatar
Use Never Seize on the threads as it is a pipe thread and it seals on the taper... U dont want to strip or gauld the threads up, had a couple buddies mess there rails up not using never seize!
Old 01-26-2010, 11:18 AM
Nasty N8's Avatar
No they are O-ring fittigns and seal with an O-ring. The rails are pipe thread and need sealant. Antiseise is not a sealant.
Old 01-26-2010, 06:00 PM
n20kid's Avatar
The NPT threads are designed to seal at 75% thread depth, if u went to machinist school u would know this... it does not need sealant, unless ur threads are jacked up then u could use sealant but i would get another fitting and or chase threads....
Old 01-27-2010, 08:37 AM
Texhotrod593's Avatar
if it leaks it wouldnt be air! this is fuel...i would and have always put paste on my threads. thats just for me though, not someone elses car. i have never had a problem and im betting nate hasnt either
Old 01-27-2010, 09:19 AM
n20kid's Avatar
Everyone has there own way of doing things and that is fine, in my many years in this business i have not had to use paste except a couple times if the threads were tapped too deep and wouldnt seal.. i just gave some advice earlier and he called me out on what i said and his statement is not true, the threads are designed at 75% thread depth to seal themselves.. Call any machinist and he will tell u the same, but none the less either way shall work not trying to start a pissing match here.
Old 01-27-2010, 10:20 AM
LS1TECH Sponsor
Lonnies Performance's Avatar
The fact is that NPT threads should not require sealant... but fuel rails are often a problem due to the thin walled nature of the extrusion.
If you cannot tighten them too tight, they may split. A little sealant never hurts if done properly. Better safe than sorry.
Old 01-27-2010, 10:46 AM
true dat^
Quick Reply: Victor Jr. fuel rail question
