should i upgrade my fuel system?
im in the process of putting heads on my car and im sure its gonna make around 440-450 being that its an auto with a stall. im curious if im gonna need to upgrade the fuel system or pump? eventually im going with some nitrous as well. should i just do it now or save it for later?
what year is your car?
either way, honestly, you will want to make a fuel pump & injector upgrade.
I suggest a Racetronix 255 pump kit WITH WIRING HARNESS. For injectors I recommend36# or larger Flow Matched injectors.
please check out www.rceng.com and then click the Technical Sizing link on the left...if you have any questions post up or PM me.
i would do it now and like zl1killa said or use a walbro gs340 with wiring harness and i would go with like 42# injectors depending on shot of nitrous you plan on running
