walbro GSL392
Old 01-23-2010, 02:06 PM
danbap's Avatar
Default walbro GSL392
I'm trying to figure out what i want to run for a fuel pump. i just cant see spending $300+ for a A1000. I'm not trying to skimp on the fuel pump just trying to save some money. i have a 6.0l that will be fed by a D1SC and its going to be a blow-through carb set up with meth injection. would the GSL392 be enough to feed this? going to be using a aeromotive 13202 reg.
thanks,
Dan.
Old 01-27-2010, 02:08 AM
uphigh07's Avatar
how much boost do you plan on running?
Old 01-27-2010, 04:16 PM
Nasty N8's Avatar
The inline Walbro will make about 550rwhp if your goal is more than that you need a better pump. Some really good pumps out there to match your power needs.
Old 01-27-2010, 04:57 PM
danbap's Avatar
im not 100% yet on how much boost, not sure if im going to change out rods and pistons or leave them stock if i leave them stock im going to shoot for 550rwhp not sure how much boost would be to make that. if i get forged rods and pistons probably 12-15psi not sure what kind of power that would make.
nate just noticed your local to me, i use to work in crystal lake.
Old 01-27-2010, 10:40 PM
dudeman's Avatar
what if he ran dual external pumps?
Old 01-28-2010, 12:26 AM
uphigh07's Avatar
why not just run 2 intake pumps? be done up till like 1000hp. do it once and do it right and run the sencond pump on a hobbs switch for when you go into boost
Old 01-28-2010, 04:26 PM
danbap's Avatar
thats what i want to do is run dual intake pumps but know one makes anything for the fox body mustangs. i cant believe it you can get everything else but not a drop in dual pump set up! if you know of any one please point me their direction
Old 01-28-2010, 08:57 PM
LS1TECH Sponsor
Lonnies Performance's Avatar
If you want a dual intank setup, I can build you one.
Feel free to give me a call.
Old 01-29-2010, 08:52 PM
danbap's Avatar
ill give you a call tomorrow, thanks.
Quick Reply: walbro GSL392
