Fueling help???
Fueling help???
Well for starters i was planning on a turbo build but plans have changed and i just gonna do a h/c nitrous car, i sold my fuel rail and injectors so i need to figure out what i am going to do
I am thinking speed inc. budget fuel rails but i dont know what size injectors i should go with. My cam is the torquer v2 and i am planning on some stock used ls6 heads... will 30 pound injectors be too much?
The nitrous is a zex wet kit so that shouldnt matter about injectors right?
Also should i do a hot wire kit for my fuel pump? and should i go with a walbro or will the stock pump be ok?
30# Ford injectors will probably be right around 80-85% duty cycle with that motor setup, will it hold ? yes, but if you get better mods down the road they wont be enough...you will need an aftermarket pump with nitrous, especially with a modified engine... i used the Racetonix kit, with good results, on an 01 Camaro I used to have
+1
Racetronix pump with hotwire kit. Install was easy and works great. I also have the TV2, and soon will be getting 30# SVO's. They should do you just fine, even with the LS6 heads. When you get it tuned just have them check the duty cycle, which I'm sure they would do anyways.
