Ford Green Tops overkill on H/C/I LS1?
Found a set of flow-matched Ford green tops, 42# at Ford pressure from what I believe, and am worried that they would be overkill on a H/C/I LS1. Worked 243's, LS6 intake, 232/234 .595 .598 cam, full exhaust. Can anyone shed some light? Using a calculator it showed 36# would probably do it, would a low duty cycle on larger injectors do any harm? Any help is appreciated. Thanks, Allen
my tuner is going to have to tune my car after i buy the same injectors. look at my signature i have the same mods just not the heads. it wont be over kill but if u put them in without a tune it will.
