Injector size?
Injector size?
I was wondering if my 28# stock injectors would be big enough for my car. I have an lq4 with milled heads and a texas speed 228r cam and it is going in a 68 nova. It will get a tune from someone and the car will have 1 3/4 headers
you must run those at 58 psi as they are really 24lb injectors, with the higher compression and the 228 you will be almost maxed a 32 at 3bar would be 36 at 58psi which would be my choice,
