99-02 racetronix kit on a 98?
LS1TECH Sponsor
The 98 kit has a sleeve that allows pump mounting as well as a different fuel sock for use in the 98 tank.
Yes you can probably make it work, but no need unless you are getting it very cheap.
Personally I would do it right the first time.
I also keep both kits in stock.
Thanks for the heads up. What's the 98 kit cost? Does the hotwire kit work with it, or is that different too? I've got a price of $150 for a low mileage pump kit with harness... didn't think that was too bad at all...
