Fuel setup for D1SC build
Ok so I've been collecting funds and waiting closer to spring to start my procharger build. Obviously an important part is the fuel setup.
A little background:
I'll be on the stock motor running about 8psi but will be upping it once I build a boost ready motor.
I already bought 60# injectors but I need the rest.
I was thinking a Walbro 255 pump with a racetronix hotwire kit because thats probably all I need while on the stock motor.
Now what other options would you guys suggest. How much more would I have to spend to do it though? I just want suggestions on what would work the best with my set up.
All you need is the pump and hotwire kit, but meth would help with fuel and add some safety.
You can save some money for the long run and do the dual pumps now and have safe fuel without the need for meth. Easy upgrade to 1000rwhp kit in the future for more boost. Give either me or Lonnie a call and do it right the first time.
