injector ?'s please come in
im installing ms3 cam,3600 stall, 373's, already have LT's and lid and msd wires, should i go with 42lb injectors? any input or opinions thanks guys
What car? What intake manifold? Cyl heads with it? Stock inj will make about 400rwhp as with the stock fuel pump. If you are planning on approching that point I would rec. replacing both. If you want feel free to shoot me a call I can help you decide where your at.
2002 camaro z28, 3600 stall a4, ls6 intake, stock 241 heads, putting in ms3 113lsa looking for some heads before everything goes in the car next week, but if i dont find a set of used ones ill wait for them and put them on later. and if i did want to change injectors/fuel pump, id go with the greentop ford 42lbs injectors with a racetronix fuel pump..
