Skool me on truck injectors and connectors..
Old 02-23-2010, 09:13 AM
Scrambler83's Avatar
Default Skool me on truck injectors and connectors..
I am in the process of building a wiring harness for an engine going into a jeep. Its a 5.3l with 243 head and a comp cams xe269h camshaft. I am currently running a stock truck manifold with stock injectors (17113698). The connectors from the harness, from a 2005 6.0l truck, wont fit. What connector do I need to get my current injectors to work with my current harness? Would it be worth going with an injector of a 2005 vortec engine =>I am thinking with a good tune this engine should be able to make ~350 hp, will the stock 5.3l injectors provide enough flow to make that power?
Any input would be appreciated.
Old 02-23-2010, 10:20 AM
Nasty N8's Avatar
I would do newer injectors the early truck inj are hard to find the connectors for. If you switch to an EV1or6 you will have no problem finding any size inj you need.
