High Flow LSx Injectors All Flow Matched
Old 02-26-2010, 02:07 PM
LS1TECH Sponsor
JeremyF's Avatar
Default High Flow LSx Injectors All Flow Matched
We now are offering high flow injectors for Just about any LS based vehicle in need of a bigger fuel supply for all that additional horse power you have added or are going to add.
We now have available and in stock GM factory re sized injectors for LS1/LS6, LS2 and LS/7's that are flow matched and upgraded to support 750 + horse power applications.
We can also custom make a set based on your wants and needs, or get you another non LSx set depending on your application.
LS2 72lbs:
$325.00 shipped - lower 48.
Perfect for any LS2 car in need of more fuel with no adapter's needed, will also work with LS1 and LS3 but will require either spacers or injector connector adapters. Able to support up to 750 + hp. The 60lbs is based on 3 bar, or 43.5 psi, where as LS cars run 4 bar at 58psi, which on LS fuel pressure of 58 is 72.25lbs. If needed we may be able provide the adapter kit based on your specific application.
LS3 72lbs:
Perfect for any LS3/L76/LS7 car in need of more fuel with no adapter's needed, will also work with LS1 and LS2 but will require either spacers or injector connector adapters. Able to support up to 750 + hp. The 60lbs is based on 3 bar, or 43.5 psi, where as LS cars run 4 bar at 58psi, which on LS fuel pressure of 58, is 72.25lbs.
LS1 48lbs:
$300.00 shipped - lower 48
We can provide an injector flow rate slope for these injectors.
Please call us at 813 476 7364 for Visa, MC, and AMEX payment, or you can Paypal at fastprom@tampabay.rr.com
If you use Paypal, please include your shipping address or reply/PM back here with it.
Our address is
Fasterproms
19103 Sunlake Blvd
Lutz, FL 33558
Old 02-26-2010, 06:30 PM
TheGovernorZ06's Avatar
cool, i have the 72#
Old 03-08-2010, 02:58 PM
LS1TECH Sponsor
JeremyF's Avatar
We have plenty of LS1, LS2 and LS3/7 "shorty" injectors available.
If you use Paypal, please include your shipping address.
Thank you
Old 03-17-2010, 09:20 AM
LS1TECH Sponsor
JeremyF's Avatar
St Patty's Day bump TTT
Old 03-22-2010, 11:23 AM
LS1TECH Sponsor
JeremyF's Avatar
We can also get a custom set made for your application, just let us know what you need.
Old 03-29-2010, 12:10 PM
LS1TECH Sponsor
JeremyF's Avatar
Monday bump!
Old 04-05-2010, 12:33 PM
qc97z's Avatar
Will these also fit LT1 fuel rails and LT1 intake manifold?
I'm doing a 383 procharged LT1, and have EFI Connection (swap to LS1 pcm, harness, ignition).
Do you have these available in 84#, high impedance? (no injector driver boxes, will run off standard harness, etc).
Old 04-05-2010, 02:53 PM
LS1TECH Sponsor
JeremyF's Avatar
What is listed, will not work, but we have a set of Siemen Deka 82# that are high impedance EV1's that are plug and play for your set up. These also are flow matched. Shipped $399.99 If you have an adjustable fuel regulator you can go up to about 86 lbs with these.
Let me know if we can help.
Thanks
Dan
Fasterproms
Old 04-05-2010, 06:54 PM
qc97z's Avatar
82# would work just fine. I'm not quite to the point of being able to purchase yet, but I'll definitely let you know when I have funding available. Should only be a few weeks.
Old 04-06-2010, 09:02 AM
LS1TECH Sponsor
JeremyF's Avatar
No worries, would love to help, just let us know.
Thanks
Dan
Fasterproms
Old 04-22-2010, 12:17 PM
LS1TECH Sponsor
JeremyF's Avatar
Precision flow matched LSx injectors all available for anyone needing more fuel with the ease and convenience of a drop in injector.
Old 04-22-2010, 02:40 PM
NemeSS's Avatar
are cores required?
can the stock ls1/ls6 26 or 28.8lbs. be upgraded to flow 60lb.s?
or is 48lb. the max flow?
Old 04-22-2010, 02:45 PM
LS1TECH Sponsor
JeremyF's Avatar
Originally Posted by NemeSS
are cores required?
Cores are not required.
LS1/6 max is 48lb at 4 bar (58.5psi)
IF you NEED 60's - Siemens 60's with work, a flow matched set is $399.00 shipped.
Thanks
Dan
Fasterproms
Old 04-27-2010, 09:55 AM
LS1TECH Sponsor
JeremyF's Avatar
TTT - thank you
Old 05-04-2010, 03:58 PM
qc97z's Avatar
Thanks
Dan
Fasterproms
Ready to buy...sent you a PM.
Old 05-12-2010, 04:56 PM
LS1TECH Sponsor
JeremyF's Avatar
Glad to have helped, thank you very much.
Dan
Old 05-13-2010, 04:39 PM
TOTM: January 2007
Last Call's Avatar
Looking for 60# in the 8.1 Marine style injector. Do you have them?
I have a Maggie and wanted to avoid adding spacers to the fuel rail.
Old 05-14-2010, 09:57 AM
LS1TECH Sponsor
JeremyF's Avatar
We use the factory GM Bosch LS2 - theu are drop in and 07 and up use the same plug.
Old 05-14-2010, 11:12 AM
LS1TECH Sponsor
JeremyF's Avatar
Jason, I called you right back - but got your voice mail.
The LS2 60lbs with adapters and larger O-rings are what will work for you set up. To go any bigger than what you have in there right now, you will need to make a custom set, these LS2's would be the easiest and best fit - especially for tuning, for what you need. Your cost with the adapters and O rings would be $399.95.
Thanks
Dan
Old 05-16-2010, 03:58 PM
1999 SS's Avatar
can you PM me a price for 80 lb ls1 injectors. i need a set in the next week or so.
