Comparing pushlock fuel line brands...
So i was wondering if the Summit brand "twist tite" fuel line will work with the same fittings the work with my Aeromotive pushlock hose. I have a small piece of aeromotive pushlock hose and fittings that work with that and would like to use the summit "twist tite" to save around $25 but just curious as the summit mag faintly says it should be used with their "twist tite" fittings.
Anybody have experiece witht the summit brand?
Thanks!
Thanks!
Aren't tranny lines higher temp and pressure than fuel lines? If the summit stuff works for tranny lines it should be overkill for fuel lines, or am I missing something. Do not want to go cheap, but also do not want to waste any money.
i used push lock on my whole build (click on link in sig)
fragola is the brand i used. and its way easy to install the hose to fittings, i did srainless braided for my oil return and i hated it
