Fuel rail fitting for electronic fuel pressure gauge
Just a quick question about the fitting needed to connect the sender to the stock fuel rail. From what I understand, it's a -6AN to 1/8NPT fitting. My question is, is this fitting something I can find locally, or is it special order only?
There are no AN fittings on a stock fuel system. I can think of two places to put the sensor on. Either on the input line or removing the shraeder valve and tapping off the open hole. I've seen after market adapters for the gm line (you can get them from Summit racing) if you want to put the sensor their and use AN lines, but that's an expensive way to do it. The cheaper way is to do it is at the schraeder valve.
