Stock Plastic Fuel Lines
Old 03-19-2010, 11:56 AM
the_merv's Avatar
Default Stock Plastic Fuel Lines
I have a 1995 Z28 so it has the stock Plastic Lines with the little metal quick-connects on the end of them.
Can you cut the line and heat it up with a good Heat Gun and re-install the quick connects?
I'm wanting to shorten the lines to re-route how I have the Fuel System setup in my car.
Has anyone done it this way..I don't see why it wouldn't work..
Old 03-19-2010, 02:54 PM
oange ss's Avatar
you're suppose to heat them in a liquid, dry heat will just melt and distort them..at least that's my experience, yours may vary...There is a special install tool kit out there for those lines but's it's like $300
Old 03-19-2010, 03:27 PM
the_merv's Avatar
Ok..so lets say I stick them in boiling water then try to get the quick connect fittings in..that will work better?
Old 03-19-2010, 06:57 PM
ROCNDAV's Avatar
You can buy replacements at Autozone in the "Help" brand section, may be they have instructions on the package.
Old 03-19-2010, 08:08 PM
oange ss's Avatar
I tried that too, you may have better luck
