Dual pump system with one in tank one out
This is a custom tank made for my 71 camaro so I am not sure how I would get a second walbro pump in the tank.
I would guess adding the external pump would require me to add a sump to the tank as that one would need to be gravtiy feed????
so after looking at my car this weekend here is my new fuel plans. Dual intank walbro gs340s, relay on each, hobbs switch on one. Pretty much the same as many others. My question is, do you guys use the Racetronix Hot wire kit or just run a thicker wire? Also, currently have -6 feed and return, should I up the fedd to -8 an? Anything else?
