injectors
injectors
What is the largest injector that will work with the stock computer in a ls1 car? I have 60s now but will need to go larger soon. I have a A1000 for the pump with upgraded lines and rails already. Any help is appreciated?
there are ID725 injectors, ID1000, & ID2000.
Respectively, 69#, 95#, 190.47# from Injector Dynamics. I believe they are all high impedance. It honestly depends on the limit hardcoded into the computer. These ratings are all at 43.5psi (3 bar)
Most injectors are rated at 3 bar. 43.5psi.
Get with FIC, they know what they are doing and the support is there if they will suite your needs
