Fuel Pump Issue?
Fuel Pump Issue?
Lately my car has not wanted to start until you turn the key off and on 3 or 4 times and then when you turn it over it will fire up. Sometimes though I can hop in it and it will start the first time. Also when it does not start and I try it a few times and then it does fire it doesn't smell like raw fuel. You can hear the fuel pump priming the system when you turn the key so it's not the relay. Once it does start it runs fine, but I do not have a wideband to verfiy proper a/f ratio. Also I had a cam (TR230) installed about 3k miles ago and my tuner had to crank the duty cycle up to around 100% on my injectors to get the a/f right. (stockers) Does this sound like a pump issue? Is there such thing as a "weak" pump? If so is this all I need to replace my stocker?
Part # 135-F99-FPA
From here
http://www.thunderracing.com/catalog...vid=3&pcid=165
Part # 135-F99-FPA
From here
