Walbo 255 problems
Old 03-31-2010, 08:23 PM
KENS WS6's Avatar
Default Walbo 255 problems
I having my 3rd pump put in my firebird for the third time.I put it in last summer 08. i hear that there was a bad production run at that time and alot of people had big problems 2 years ago.has anyone had the same problem or im just getting lemons. thanks.
Old 03-31-2010, 09:47 PM
koolaid_kid's Avatar
There was a problem. It has since been fixed. You should not have been able to find two with the same issue.
Tell us about your setup. The wiring harness is key to avoiding issues, do you have one?
Let us know.
Old 04-01-2010, 11:02 AM
LS1TECH Sponsor
Lonnies Performance's Avatar
There is more than a bad production run.
Walbro did have an issue with a certain model 255 pump, but not all.
There quite a few variations in circulation.
There are also counterfeit pumps (even with Walbro stamps) out there that have less than a spectacular reputation.
Since you are in Canada, I suggest you contact Racetronix directly.
Old 04-02-2010, 02:21 AM
SoundsZ28's Avatar
i have a walbro 255 and im having issues too. When i turn the key ON i have only 15 psi at the rail and it goes to zero in about ten seconds. if i turn the key like 3 times in a row il have 55-60 psi but it drops very fast. could this be a pump problem or possibly the regulator or internal fuel leak in tank?? And btw i have a 2000 z28 ls1
Old 04-02-2010, 05:51 AM
69LT1Bird's Avatar
sounds more like a leaking/weak regulator
Old 04-02-2010, 08:04 AM
KENS WS6's Avatar
just to let you guys know, i replaced the fuel pressure regulator and still no pressure when i take the key out.i just ordered a new walbro 255 punp and im going to try it again.I hope its not a stuck injector.
Old 04-02-2010, 01:30 PM
SoundsZ28's Avatar
im gonna try to change the regulator and go from there.. il keep you posted
Old 04-02-2010, 01:31 PM
sway99bird's Avatar
yup !!!!
Old 04-02-2010, 01:46 PM
lmt0705's Avatar
are you running stock fuel lines?
Old 04-02-2010, 03:22 PM
MIGHTYMOUSE's Avatar
bad ground
Old 04-02-2010, 04:40 PM
SoundsZ28's Avatar
yea everything is stock besides the pump. i put a walbro 255 pump in over the winter. its a cam only car... so would the ground be bad inside the tank possibly?
Old 04-04-2010, 03:23 PM
SoundsZ28's Avatar
well i pulled the pump out yesterday and found that the stock hose in the tank was cracked. i replaced that put it back together and my car runs great now
Old 04-04-2010, 05:36 PM
Ph.D. in HUBRIS
custm2500's Avatar
I am having issues with a walbro 255 I just put in my truck. Fuel pressure is dropping to zero when I excelerate, after running for a little wile. The pump is not hot and if I shut the truck off for a minute it runs normal. Anyone think it may be a problematic pump?
Old 04-05-2010, 03:31 AM
SoundsZ28's Avatar
id say its a bad pump.....
