77 ls1 corvette fuel pump
Old 04-05-2010, 04:44 PM
cmaurice876's Avatar
Default 77 ls1 corvette fuel pump
I am looking for an in tank fuel pump that is equivalent to the v8 camaro. It is going to be naturally aspirated, therefore the stock flow rates will work. I havn't been able to locate one though without buying the entire assembly.
Thanks Alot
Old 04-05-2010, 07:37 PM
Nasty N8's Avatar
What do you mean entire assembly? there are very good replacement pumps if you are going to mount and wire it yourself or I have had very good luck with Tanks Inc. They make some very nice retro swap pump assemblies to fit older tanks. And we make a line/regulator kit to connect right to your new motor. Feel free to give me a call I can help you get the parts you need to make your new motor work properly.
