Turbo Guys...?
Turbo Guys...?
I am wondering what you guys are running for your fuel system...?
I will be running stock Ls1 ls6 intake holly 90mm
Gm hotcam with ls6 springs
Kentucky turbo setup 5-10lbs boost
Thanks
Thanks
i currently have 3 walbor's in the factory tank with a 3-way manifold connecting them together before leaving the tank in -8 hose
-8 hose runs to one aftermarket fuel rail, and hops over to the other across the front with more -8
exits the rear of that rail in -6 with an elbow to mount the fuel pressure gauge sending unit in
then to a kirban race regulator with an adapter fitting to mount it to the stock feed line (now used as my return)
i ran it like this for years previous with two walbro pumps in the tank as well. the third is new for this year.
