98 fuel tank swap into a 01 camaro
Old 04-09-2010, 10:36 PM
chevyz2801's Avatar
Default 98 fuel tank swap into a 01 camaro
Think im going to swap a 98 tank into my 01 camaro has anyone done it or can tell me what problems ill run into Thanks for any info.
Old 04-12-2010, 08:56 PM
chevyz2801's Avatar
I found a tank and sending unit its on its way to me. I will try to post up any info i gather on the swap and post it here.
Old 04-13-2010, 11:35 AM
pdasterly's Avatar
what other vehicles have a metal tank with the 99 style mounting circle? So I can weld that into a 98 tank. does this make sense
Old 04-13-2010, 12:31 PM
Nasty N8's Avatar
What are you trying to accomplish replacing the steel tank in your car?
Old 04-15-2010, 11:50 PM
chevyz2801's Avatar
1 i messed up the sending unit for the plastic tank
2 the steel tank has baffles so better fuel control
3 im runing 2 pumps 6an with a y to 8an out the tank with 90 bulkhead and 8an to front.
Old 04-16-2010, 10:59 AM
Nasty N8's Avatar
The sending unit in the steel tank(0-90ohm) is different than yours(40-250ohms) and your gauge wont work. I have replacement senders and properly setup dual pumps for the plastic tank that retain the factory function of the bucket.
Old 04-19-2010, 08:36 PM
chevyz2801's Avatar
both of the sending units i have go from 40-250 so it works for me.
Quick Reply: 98 fuel tank swap into a 01 camaro
