Easy way to seal wires for 2nd pump coming out of the tank?
Old 04-14-2010, 06:07 AM
czwalga00gt's Avatar
Default Easy way to seal wires for 2nd pump coming out of the tank?
I have a rx7 so things might be a little different, but it comes down to i'm going to have to drill a hole in the top of fuel door to run the extra wires out. Whats a cheap easy way to seal that hole? Liquid steel and just mold it around the wires? Seems simple enough to me, but i'm not sure about his gasoline rating.
Edit: JBweld is fine for gasoline. I was just going to run the two wires right outside the fuel door, jbweld the hole/wires. Then add a connector rigth on top of the fuel door.
Old 04-14-2010, 10:50 AM
slow trap's Avatar
rubber grommet and some goop.
