1998 Racetronix Fuel Pump Sock Missing
Old 09-21-2010, 07:29 PM
philsblwnz28's Avatar
Default 1998 Racetronix Fuel Pump Sock Missing
So I bought this racetronix fuel pump for my 98 LS1 (metal tank) and it did not come with a filter sock. So I went to the dealer and bought one for my car (stock filter) and it was the incorrect one. So I talked to Lonnie and he said that I needed a specific filter sock for the racetronix for the 98 models.
So basically my question is where can I get just the filter sock for my 98 Fuel pump w/ the racetronix pump? I need my car back up and running as its my only ride.....
Thanks in advance
Old 09-21-2010, 08:01 PM
whtrashferrari's Avatar
Default Hmmmmmm
well heres a pic of mine.. I hope this might help you!This is the one currently installed on my 98 formula maybe the shape might let the parts dude figure it out!
I had to bend my fuel level arm rod a bit in order to get my tank to read correct also its easier to get the assembly back in if you compress the swingarm on the assembly a bit with some bent needle nose "kinda pulling in a upward motion but dont actually bent the bracket" .. just FYI!
Attached Thumbnails 1998 Racetronix Fuel Pump Sock Missing-fp.jpg   1998 Racetronix Fuel Pump Sock Missing-fp1.jpg
Old 09-26-2010, 01:12 PM
kwiksilverz28's Avatar
I got mine from dealer. Fit perfect. I bet dealer sold you one for 99+
Old 09-26-2010, 01:30 PM
Quick Reply: 1998 Racetronix Fuel Pump Sock Missing
