Boost-a-Pump vs. Hotwire kit
Old 10-29-2010, 10:55 AM
RsSean's Avatar
Default Boost-a-Pump vs. Hotwire kit
I have the racetronics hotwire kit now wired to the back of the alternator. Are people with boost a pump seeing better success fuel pressure over the hotwire kit? Or are they both limited to about 650 rwhp on a single upgraded pump?
Old 11-02-2010, 06:15 PM
Meemperor's Avatar
Stock wiring will get fried from a boost a pump. The Racetronix harness is meant to work in tandem with a BAP if you need one. That's why they sell the connector set so you can plug your BAP into their harness.
Old 11-30-2010, 04:29 PM
Devils Mentor's Avatar
BAPs are sweet! When I my 3000GT VR4, I use one; you could just dial in your the volts for the pump. Also had the BAS, but that's another thread
DM
Quick Reply: Boost-a-Pump vs. Hotwire kit
