new problem
Old 06-10-2011, 11:27 AM
98goblinls1's Avatar
Default new problem
hey guys im having a bit of a problem, car is getting to the point of taking a long time to crank, at times it takes several tries to get it to crank. it seems to start better after it has run for a little while... any suggestions?
-Thanks in advance
Old 06-10-2011, 04:27 PM
deatschwerks's Avatar
Do you have a fuel pressure gauge?
I'd be curious to see if the fuel system is holding pressure.
Any fuel system mods?
Old 06-11-2011, 07:18 PM
No I don't have a gauge, or anything done to the fuel system, one thing I forgot to mention is that there seems to be a high pitched whine coming from either inside the fuel tank, or very close to the tank... Not sure what to think of this I don't know if its the pump making a fuss or not.
Old 06-13-2011, 11:42 AM
Nasty N8's Avatar
Need to put a gauge on it to know if it's holding proper pressure when having troubles.
Old 06-13-2011, 12:27 PM
Is the noise constant or do you only notice it while driving?
Recent switch to E10/E20 fuel?
Old 06-22-2011, 09:36 AM
no fuel switch, also the noise starts after the car has been driven for a while (more than 30 minutes) when the noise starts it remains constant, park and cut the car off, then cut it back on sometimes it keeps making the noise sometimes it stops.
Old 06-22-2011, 10:38 AM
02WS6Indy's Avatar
Have you replaced the fuel filter lately? If you have not might be a good time to do it and it's a cheap potential problem to eliminate. Sounds like you have a fuel pressure problem. Could be a lot of things. Like people are saying put a guage to it.
Old 06-23-2011, 06:59 AM
Old Geezer's Avatar
Tank vent?
