Fuel system upgrade?
Location: Johnsonville, SC; but orginally from GAINESVILLE, FL
I recently had a young man ask for help on a recent purchase he made. He purchased a TRANS AM that was modified with a bunch of equipment that was purchased from TEXAS SPEED and VENGENANCE RACING. The young man had a fuel pump issue and when he had it corrected at a local shop in Hawaii, the shop nor him knew exactly what was going on with the car and put a stock FUEL PUMP in the car. The car is equipped with the following:
TEXAS SPEED
- 402/408 LS1/LQ9 IRON STROKER LONG BLOCK - ITEM # 25-402IIRONLB
- COMP CAM CUSTON GRIND - 232/242 .595/.612 112LSA - ITEM # 4-CUSTOMCAM
VENGEANCE RACING
- LS1/LS2/LS6 1.8 ROCKER ARMS
- TRICK FLOW 215CC CNC PORTED HEADS 3.90 BORE
- VENGEANCE RACING FAST 96MM COMBO FOR CORVETTE
RANDOM ITEMS:
ACCEL 48lb Fuel Injectors.
These are the big items.
What do you guys recommend for the FUEL SYSTEM? BOOST-A-PUMP or a upgraded FUEL PUMP.
Also, what WATER PUMP do you guys run on these 408s and HOSE kits?
Really appreciate the help getting this car running again.
TEXAS SPEED
VENGEANCE RACING
RANDOM ITEMS:
Thanks,
Micah
Micah,
I'd go with a racetronix 255 with their hotwire kit.
If he wants to be cheap, buy just the wiring kit and see if that helps enough by itself. I don't like boost a pumps. Especially if he ran it all the time on his NA motor.
BTW, I ran a stock pump and made my numbers in my sig with it. Eventually put in a racetronix though. It wasn't out of fuel though. It's also a C5, but should be similar.
Micah,
I sold my black coupe, later bought a MY coupe and sold it and now I have the one I have always wanted...2003 TR ZO6. Cammed it, VR CAI, LTs and coil overs. All done by me.
Keep in touch bro.
Micah
