Selector switch or "T"?
Old 06-15-2011, 01:40 PM
FormulaZR's Avatar
Default Selector switch or "T"?
Ok, simple deal here. I've got a 383 carbed LS1 in my boat and am thinking about going back to EFI.
I have twin tanks, so my question is simply this:
Can I put a T on the feed and a T on the return; or do I need to run a feed/return selector valve to only feed/return to 1 tank at a time?
Old 06-15-2011, 03:12 PM
deatschwerks's Avatar
Would the engine need the combined flow from both pumps, or will one pump be able to supply enough fuel for the engine's needs?
Old 06-15-2011, 03:38 PM
FormulaZR's Avatar
One pump is enough. With either the selector or the T I plan to run only 1 external pump. Right now I only need one to support about 575 fwhp plus a 125 wet shot.
The difference is really $550 for the 6 port selector or MUCH less than $550 for some T's. Right now I'm using a T with the tanks to feed it carbed - but I didn't know if that would work with the return line.
