Fuel rails
Fuel rails
I'm gathering parts up for a cam swap I'm gonna bump up the fuel system while I'm at it I want to use edelbrock pro flow rails with my ls6 intake will this work with my intake if not what rails will any info would be great also what size injectors should I run I'm gonna have the heads and intake ported and put a good throttle body on so any recomindations on a throttle body would be great to
The LS1 rails will work (I assume you have an LS!,you did not specify)with the LS6 manifold but I would contact Edelbrock to make sure it's a direct fit. Make sure it is not designed for specific injectors and will accept any LS1 style injector. As far as size, if your not running big HP or boost anything around a 38# would suffice just remember to get it tuned right after you change them because you engine will run rich and could hurt the motor if run like that for long.
