anyone have pics of dual walbros on a 99 up with -8 line out
i read the sticky wich was a great write up but im going turbo and will be runnin larger rails with a -8 feed and -6 ret in the stock feed. anyone have pics of how they connected to the -8 bulkhead fittin in the tank? i could use this bad.
Ill b using a -8 90 bulk head w nylon washers and the goo but trying to figure out how to run the pumps I guess just a -8 to 2. -6 fuel y and push on connector with fuel inj hose and clamps? Still id love to see a pic
I'll be ordering these two parts to connect to the existing ports on the top of the the fuel pump module.
http://www.jegs.com/webapp/wcs/store...-1&showValue=1
I will be running -8 from the feed all the way up to FPR and into the rails, a crossover, and then a -6 out of the return port on the regulator to the return fitting on the tank using the above fittings to connect it.
If someone has more experience with this and has a better way i'd like to hear as well.
