GMPP L92 Intake (originally LS3 Injectors) upgrade for ProCharger - what can I use?
Old 07-06-2011, 10:14 AM
BanditDave's Avatar
Default GMPP L92 Intake (originally LS3 Injectors) upgrade for ProCharger - what can I use?
Hey Guys,
On my ProCharger build I have a GM Performance Parts L92 Intake with what is supposed to be LS3 injectors that has the EV6/USCAR Connector on it.
The conversion harness I have for it use the EV1 connectors. My issue is that I need bigger injectors - shooting for ~60lbs - but I want to make sure I can cleanly adapt them.
Is there any issue with using "FAST 57" LS2 injectors in the current place? I would imagine that the heights may be different between the two. Could I use EV1s instead? It would be a direct connection to my harness if that is the case.
Any and all help is appreciated.
Here's a shot of the intake as I bought it, but I do not believe the LS3 injectors will be enough:
Thanks!
Dave
Old 07-07-2011, 10:50 AM
onefastrx7turbo's Avatar
Dave, what are you using for the engine control? If you're using stock ecu + HP tuners or something like that, you should consider Injector Dynamics 850cc injectors.
They equate to roughly 80lbs injectors...
Last edited by MeentSS02; 07-08-2011 at 09:24 PM. Reason: Non-sponsor link removed
Old 07-07-2011, 10:07 PM
BanditDave's Avatar
Actually yes, I am using a Fbody ECU with HPTuners...I can get the adapters for the connectors...this is really good info man, thanks!
Old 07-08-2011, 03:49 PM
FICINJECTORS's Avatar
take a look at ours.. they are on sale and are available in 52, 60, 72 ,80 and 95lbs
http://www.corvetteinjectors.com/sho...?productid=376
Quick Reply: GMPP L92 Intake (originally LS3 Injectors) upgrade for ProCharger - what can I use?
